ktmchrisv
Hi all,
I just received an old KayPro 4/84 with the poplular Mini Winnie hard disk controller, and the Advent TurboROM V3.0 that was supposedly modified to be able to boot directly from the Mini Winnie controller.
The reviews of this board indicate that it was roughly 2x the performance of the standard WD1002 controller.
I have cleaned up the system and connected a 20MB ST-225 to the controller on DS1. When running ADVFMT or K10FMT, the program hangs in a timeout for a bit, and then comes back with a timeout failure. If I disconnect the drive, then the program errors out right away without the timeout. I think the Mini Winnie controller is sitting on the same IO addresses as the WD1002 K10 controller. Probably without having the controller reset line inverted.
In reading the reviews about this board, there was an installer program distributed in source form that would format/partition the drive and create two executables; a diagnostic for the exact drive connected, and a bios driver to support the controller / drive when BIOS support is not available for cold boot.
I'm looking to see if someone on the forum may have this installer program. Mini Winnie was a very popular controller for all of the old CPM systems with a socketed Z80. So, it may show up in archives for Morrow, Osborne or other of the larger CPM system manufacturers. I have been scouring the web and haven't found much beyond the reviews of the board.
Chris
Chris
