glitch
I've got a Kaypro II with no power supply, what current ratings do I need to satisfy to shoehorn a modern switching supply in there?
In my Kaypro 4/83, in which I have added a 10 MB MFM harddisk + controller, I put in a MW MPT-120B Triple Output supply.
It is almost a perfect match only slightly less length (needed to drill two new holes). I could even reuse the original Kaypro connector.
Thanks for the tip. My Kaypro II Astec AA12350 power supply seems to have died after the main RIFA smoked and I replaced all 3 RIFA's. So I managed to find an MPT-120B locally in Australia very cheap on clearance after finding this thread so will go with that option.In my Kaypro 4/83, in which I have added a 10 MB MFM harddisk + controller, I put in a MW MPT-120B Triple Output supply.
The Kaypro 4/83 and 4/84 have a builtin HDD controller. The Kaypro II does not. If you can find one there is a 8088 DOS upgrade system consisting of 2 cards. Use your machine as an Early MS DOS computer. Whenever they come up on eBay its usually just one of the cards not a complete set.Thanks for the tip. My Kaypro II Astec AA12350 power supply seems to have died after the main RIFA smoked and I replaced all 3 RIFA's. So I managed to find an MPT-120B locally in Australia very cheap on clearance after finding this thread so will go with that option.
How did you end up reusing the original power connector? Switch pins, cut?
Also, where did you find a suitable hard disk controller?
Cheers
Thanks for that info VERAULT. The reason I was looking for a hard disk controller is that I was exploring connecting up a FreHD to my Kaypro II as I assumed you still needed a HD controller but I now know you don't. And as you appear to be all too aware (I saw your attempts on a couple of threads), integrating a FreHD into a Kaypro II is either very difficult or maybe impossible without all the correct bits and info. So I am yet to decide if I want to give it a go.The Kaypro 4/83 and 4/84 have a builtin HDD controller. The Kaypro II does not. If you can find one there is a 8088 DOS upgrade system consisting of 2 cards. Use your machine as an Early MS DOS computer. Whenever they come up on eBay its usually just one of the cards not a complete set.
Sorry for the late reply.Thanks for the tip. My Kaypro II Astec AA12350 power supply seems to have died after the main RIFA smoked and I replaced all 3 RIFA's. So I managed to find an MPT-120B locally in Australia very cheap on clearance after finding this thread so will go with that option.
Cheers
The Kaypro 4/83 here does not have a HDD controller, nor a connector or pads to connect one. I ended up connecting an ISA 8 bit MFM controller with a small ratsnest of cables and a self-written driver.The Kaypro 4/83 and 4/84 have a builtin HDD controller. The Kaypro II does not. If you can find one there is a 8088 DOS upgrade system consisting of 2 cards. Use your machine as an Early MS DOS computer. Whenever they come up on eBay its usually just one of the cards not a complete set.
Thank you. Yes I was amazed that when I actually got the new power supply in my hands it was actually pin compatible except for needing to cut the connector. I wasn’t going to cut it as I like to keep everythhing original but can still be used with the original power supply if I ever repair it. Have not been well lately so will get back to it all soon.Sorry for the late reply.
I cut the original connector in two parts (AC and DC) and then the separate parts matched the layout of the pins of the MeanWell supply.
The harddisk controller is a homebrew adaptation of an ISA 8 bit controller from WD. I needed to write my own drivers though.
Firstly, hope you are feeling better.Thank you. Yes I was amazed that when I actually got the new power supply in my hands it was actually pin compatible except for needing to cut the connector. I wasn’t going to cut it as I like to keep everything original but can still be used with the original power supply if I ever repair it. Have not been well lately so will get back to it all soon.
