Formulator
Recently acquired one of these locally. Cosmetically in very good shape, and came with travel pouch. Sadly, no disks or manuals.
Neither of the TM-100 drives work well; the A: will not boot and the B: boots, but has a broken latch. I just want to make sure the Shunt 1E jumpering is correct, as what the technical manual (1484-C) states seems unclear:
It states that A: should be jumpered 1/14, 2/13 and B: 1/14, 3/12. Since there are 16 pins in the shunt, you could understand my confusion. Anyway, I can probably fix the drives eventually, but just want to confirm the correct jumpering. Thanks.
A: is on the left.
A: is on the left.
