1ST1
Hello, I just transfered one of my Olivetti M24 from DOS 3.20 to DOS 5.0. I made a boot disk on another M24 which already runs DOS 5. So I booted the 1st M24 from floppy, made a SYS C: and started Guest.exe for the ZIP drive to copy the dos folder from ZIP disk to harddisk to get the updated commands for DOS 5. But I forgot to change some commands in config.sys and autoexec.bat.
So I booted that M24 and it was just fine, running DOS 5 now, with german keyboard layout. Then I thought, oh, you can add doskey and some more luxury things into config.sys and autoexec, and I did that. While that, I saw that in the autoexec there is the command
keybgr
for german keyboard, this was still the DOS 3.20 command. So I changed it into
keyb gr,,c:\dos\keyboard.sys
and rebooted. But surprisingly when executing this command, the M24 hangs totally up, no CTRL+ALT+DEL anymore, nothing.
After resetting and booting from Floppy, I changed back to
keybgr
and everything was fine. Why?
keybgr
keybgr
