mikerofone
Glad to hear they helped! FWIW, the brightness control on my computer also barely does anything. Just enough such that I think it does have an effect.Thanks for the pictures. They are very helpful. I have been struggling with my own 486c for a while. My problem is that I can not adjust the brightness of the screen at all. I had been concentrating on the little board with the speaker on it but I may have to actually venture out and open up the whole display panel. Did you replace any of the tiny SMD capacitors?
I did not replace any caps on the second board in my pictures, only the ones described on the first one which included the four smaller 47uF (?) SMD caps.
The plastic on my machine was suprisingly easy to work with, nothing snapped!I am seeing some of this as well which I had attributed to failing caps but given how minimal it is I was willing to ignore it. If I end up opening up the panel itself I may then have to replace those as well as I don't want to reopen this machine again (the plastic is already very brittle)
I guess you mean the Compaq Setup utility? It showed a 486/33 but I guess that might be bogus. I also couldn't find the 486c/66 utility, only the non-/66 one on this website (link at the end of the post): https://www.retropaq.com/setting-up-the-compaq-portable-486/Interesting. I tried upgrading mine with a working AMD Power Stacker 486 to 133 MHz 5X86 (i.e. works in other motherboards) and the system refused to boot. I have an Intel 486DX4-100 OD chip in there and it has been quite happy with that. I am wondering if the BIOS in the 486c/66 is different then the one in the original model and allows for the AMD chips to work. Can you tell me what the ESU identifies your CPU as please? TIA!
The tool reported that the config settings were stored in "nonvolatile memory" by a newer version of the software, so maybe a newer utility can show more. Since my computer is reporting a configuration error when starting (seems an ISDN card has been removed), I'll need to give configuration a try, but I wonder whether I can ruin anything if I use the older tool.
Edit2: Here are some pictures of the CPU installed. Quite the stack of adapters was needed, apparently.
Do you have the /66 config disks? If so, mind sharing the disk images? That would be awesome!
Cheers
Nikolai
Edit: Just for reference, in case you or anyone looking doesn't have it yet: The service manual is quite helpful for disassembling the machine. Available at minuszerodegrees. The machine is much easier to work with than that NEC PowerMate Portable luggable I have worked on before. Compaq clearly intended for people to service this machine without drowning in screws.
