California Left over pdp 11 boards in partially torched rack, in two cabinets
Covers: California
dluck
Campbell, CA
Delivery Options
Local Pickup Only
Dropping price to $200 for the last rack and all contents. Pick up in San Carlos, California.
Added some additional info.
Top Chassis 11/34 heavily damaged chassis
Included boards, some damaged:
M8134,M8139,M8140,M8138<M8123,M8136,M8141
M8130,M8132,M8137,M8135
The middle/lower chassis' hardware don't appear damaged by fire as only the upper part of the 19" rack seemed to have been affected by fire.
Middle chassis:
slots 1-6: M7807,M7836,M7837,M7838,M7839,M7839
7,8: empty
9: M7147, M920
10: M920
11: M7807,m920
12:M7821,M796,M7147
13-15: M7278,M7277,M7289
16: M7821,M7280
17: M5906,M7280
18: M7288
19: M7279, M4540,M920
20-21: M920
22: M7819
A couple of the fascia plastic pieces are slightly damaged
Bottom chassis only has 1/2 backplane.
7: empty
8: M7147
There are a couple large ribbon cables coming from a couple boards. Although the ribbon cables appear undamaged, the end connectors were cut off.
The DEC Power Control Unit 861C on the bottom of the rack in the back appears to be in good shape.
Everything is as is, no warranty. I tried to describe it all as best as I can. Nothing plugged in or tested.
The boards in the middle and bottom chassis don't appear to have any damage. The metal chassis' do not appear damaged. There is some rust. They chassis' slide in and out of the 19" rack.
Sure, I'm willing to take this on if you still have it.
I'm hoping you might be able to wait for pickup until after VCF?
are those still available?
Michael
I wound up with that mess. Heartbreaking to see the carnage, particularly to the 11/70 boards that were somehow in the rack.
I don't need all the parts though, so you can PM me if there are boards or backplanes out of the two lower BA11s you need.
