alejack12001
Could LISP run on an XT machine? If is is there a compiler that would support LISP on XT type machine?
For assorted values of "Full".Not only does it run on i8086, but it fits in a boot sector. Apparently it's a full implementation.
Good heavens!But they made it by writing a 8088 emulator in 6502 assembly that would at least partially emulate the code they wrote for MS-DOS!
There's actually a lot of interest in Lisp today. I can't say more or less than in the past, but probably more, simply because there are more folks in the field (percentage wise the numbers may not be that different, but absolute numbers I'm sure is higher).Wow, I didn’t think there was as much interest in LISP now a days.
LispWorks is doing fine... they just released version 8.0 with native support for Apple silicon Mac.I used Harlequins LispWorks in the mid 90's on the PC, I was using Scheme earlier than that on Unix boxes.
