mlaferriere
- Joined
- May 19, 2016
- Messages
- 84
It has been a long time since I had a functional Model-I. But I recall having a serial cable that hooked up my Model-I (which had two floppy drives) to my Cocos (which had no floppys). I vaguely recall having a program to cload software from the serial port. The speed of this would be set by the serial ports. This required no additional software on the Coco and even back then it didn’t seem to be well known. The Model-I (or compatible) would run a program which would allow you to load in a file from disk and stream it over the serial port to the CoCo.
I have tried several searchs and haven’t been able to find any discussions on this. I am in the process of getting my machines functional again. Does anyone recall using this method to get software onto a CoCo? It would be a good way to share files to a CoCo if you have a FreHD or similar. I believe it worked for basic and machine language programs.
