JoJo_ReloadeD
- Joined
- May 12, 2007
- Messages
- 120
Here is Lobo, my latest build. Just trying to achieve the top possible performance on a 16 bit PC... while paying tribute to this game saga that was born on 16 bit PCs, Wolfenstein
Here are its specs:
- 80286 at 27.2 mhz
- 4 mb ram on motherboard
- 2 mb EMS
- VGA Cirrus Logic 1MB
- Sound Blaster 16
- integrated Roland MT32
- Ethernet network card
- Storage on removable CFs
Inspired by the Highscreen 286 video, I decided to investigate how to build a 286 gaming PC and see how far can I go... and this is the result.
Built in a Nox Hummer ZN case, this PC... is in fact two PCs in one. There is no LAPC-1 card on it, the MT32 support is 'emulated': Inside Lobo there are two Pcs, the main one, the 286... and a P4 3000 which its only job is to emulate the MT32 via software using MUNT.
Build photos:
Halfway... note the big heatsink over the 286, and another small one on the chipset, because of the overclocking.
First build, but everything fits on the case
MUNT was originally done to be used with DosBox and ScummVM, adding a midi instrument on the computer its running, and dosbox/scummvm connect to it generating the sound. I was thinking about this concept and thought... 'if I have one software midi equipment on a pc... connect a midi usb adapter... and link them... it should react to midi commands entering throught the serial interface, right?'
Yes, that was the case
Built all on a linux, linked the midi devices and converted that PC on a real MT32 card :D
The rest was simple, just having a powerful enough PC to get the emulator running, connect it to the 286 through the SB16 MIDI port... and that's it
Back photo
... But still I wanted to give some more touch to Lobo. As I had a nice case I thought of giving him a booting sound 'a la Apple':
https://www.youtube.com/watch?v=DHRc2YwHWiI
Yep, when booting the PC we hear a wolf howling... This is the real Lobo... :D
Now, I had to automate everything so that we power the 2 PCs and play the sound effect just when you press the power button ... I had to coordinate the on and off of 2 PCs in different ways: One is standard AT what is a simple switch that turns on or off ... and another ATX, where we have a button to be activated once and a while just to power it ... and repeat the process to shut down.
I decided to ride around with an Arduino UNO and a relay board to control this, and take the chance also to reproduce the sound of howling wolf using the technique of PWM. This Arduino powered by + 5V line ATX standby, so that when the ATX power source has the Arduino is powered and monitoring the power button.
Here is Lobo working and playing games:
* Please play the video at 720p50
I hope you like the build
Here are its specs:
- 80286 at 27.2 mhz
- 2 mb EMS
- Sound Blaster 16
Build photos:
Back photo
