| VCF SoCal | Feb TBD, 2027, | Southern CA |
| VCF East | Apr TBD, 2027, | InfoAge, Wall, NJ |
| VCF Latam | TBD, 2027, | Bahía Blanca, Argentina |
| VCF Pac. NW | TBD , 2027, | Tukwila, WA |
| VCF Southwest | TBD, 2027, | Westin Dallas Fort Worth Airport |
| VCF Southeast | Aug TBD, 2027, | Atlanta, GA |
| VCF West | Aug TBD, 2027, | Mountain View, CA |
I see. So if i download this file and use TRSTOOLS to insert the file into the disk images that would solve my problem?The 4p (& 4) won't boot Model I disks. The 4p lacks the Model III ROM (which the 4 has), so your Model III bootdisk needs to contain a file called MODELA/III which is a copy of the Model III ROM. There's a link on Tim Mann's xtrs webpage to download it.
HTH, Tom
Sure - please post one of the images which wrote out a good disk but cannot be opened by TRSTools.One thing i noticed today was trstools seemed to only be able to open maybe one out of every 8 disk images. Even good disk images I had no problem writing to a real disk with a greaseweazle. Why is that? I can post a disk image like that if it helps.
Ok here is one for example. If I use HXC tools to convert it to a raw stream I can write it to disk just fine. Boots and plays no problem. But the disk image WILL NOT open in TRSTOOLS. I have others as well.Sure - please post one of the images which wrote out a good disk but cannot be opened by TRSTools.
Zaxxon is a copy protected disk, not a regular DOS/Non-DOS disk. Nothing should be able to open it.Ok here is one for example. If I use HXC tools to convert it to a raw stream I can write it to disk just fine. Boots and plays no problem. But the disk image WILL NOT open in TRSTOOLS. I have others as well.
I'm thsts just one example. Ill post some more.Zaxxon is a copy protected disk, not a regular DOS/Non-DOS disk. Nothing should be able to open it.
Hmm I guess your right about the copy protection. Here is another few that I cant do. I guess I never really thought too much about trs-80 software as having copy protection.Zaxxon is a copy protected disk, not a regular DOS/Non-DOS disk. Nothing should be able to open it.
Hi - Those are also all self-booting or special disks. No tool is ever going to open these kinds of disks as they are not based on any DOS, nor do they have a directory track.Hmm I guess your right about the copy protection. Here is another few that I cant do. I guess I never really thought too much about trs-80 software as having copy protection.
So these disks cannot be re-written to actual floppies and can only be used with emulators?Hi - Those are also all self-booting or special disks. No tool is ever going to open these kinds of disks as they are not based on any DOS, nor do they have a directory track.
Those disks can absolutely be output via hardware to create a real 5.25" disk, but you would need a GreaseWeasel or CatWeasel or the like to do so. This has nothing to do with TRSTools.So these disks cannot be re-written to actual floppies and can only be used with emulators?
And specifically, it has to be in the right place on the disk. I can’t remember off the top of my head, but I think MODELA/III has to be the first file on the disk.The 4p (& 4) won't boot Model I disks. The 4p lacks the Model III ROM (which the 4 has), so your Model III bootdisk needs to contain a file called MODELA/III which is a copy of the Model III ROM.
Does trstools allow you to change the order of files on disk images? I still dont have a working disk.And specifically, it has to be in the right place on the disk. I can’t remember off the top of my head, but I think MODELA/III has to be the first file on the disk.
