Thrashbarg
Hi,
I've come up with a crazy short term project... converting a Mac Classic into a B&W television. I'm sure I can do it myself, it's just a matter of changing some components to suit the slightly lower time base used in PAL television. The line rate for PAL is 15625Hz and I believe the line rate for the Mac display is about 24kHz (24624Hz = 72Hz * 342 lines).
So, has it been done before?
