Is it just me or do the traces LOOK bad in that first photo, have you checked the ones that look dark/corroded?okay, i havn't been able to identify the ways the traces go except for the 2 on the bottom of the switch in the above image, maybe someone can help?
i've taken a image of the front of the board and under for help
button, top right corner
button pinns top left corner
not both batteries are bad, just the 2nd one but i guess i could clip that one out, btw i've never changed surface mounted caps before so i wouldn't know how to or even what specs these caps have.
i tried my 9v battery on the same pinns and couldn't get the mac to start
I checked my board, and those holes are pretty small... if they're holes at all. They may be traces from one side of the mainboard to the other - I'm not sure.
I used this site to re-cap my Macintosh II (and a IIx, and two IIcx's):
http://inbox.apana.org.au/?p=1342
Personally, I wouldn't try shoving anything through those holes.
One and the same....Phosgene... As in First World War chemical weapons? Okay, I'm glad I skipped that step now
Thanks for the heads-up
