Well that nails it
Without a valid original sense code the (or at least my) 4.8 card does not output any video signal.
I connected Sense 1 to ground (RGB 15" monitor type) and the display leapt into life With a refresh rate of 75hz its well within my LCD monitors capability.
Just need to rebuild the machine now and see if the HD has any life left in it (and strip the floppy, never seen so much crap, its slot must be the major inflow of air to the chassis !
I can hear the hard drive spin up, then spin down so I think its dead
Certainly not. I've experienced that as well. I have a few Macs with two video cards and there's no way to get a picture on the second card unless a display was connected when powering on. Otherwise, the card does not produce a video signal. So it is safe to say: no sense pins = no video signal.That's weird, I've never seen a Mac II video card that required a monitor to be present to boot properly. Usually it just blasts out a signal regardless if something is connected or not.
Of course, that's the whole point and the reason why the cards don't give video with nothing connected.There are sense pins in the cable. I thought for Apple branded cards at least that was always the case.
It doesn't need to know. Videos cards on the Mac are either dedicated monochrome or dedicated color cards.How is a computer/cards going to know to produce mono or color video?
While the sense pins are described by Apple as selecting the monitor size, what they really do is to select the display resolution. The Performa 6200 may only support VGA resolutions.
The machine has 1 mb of shared video memory and supports 640x480 @ 15bpp, or 800x600 and 832x624 @ 8bpp.
Owing to the junk architecture of the Performa 62xx (putting a 64 bit CPU on a 32 bit bus, and using 68040 and 68030 bus emulators with slower devices), higher resolutions make the machine even slower than it already is. I had a Performa 6320 which used the same architecture with a faster 120 MHz 603e and it was just as painful.
Your mileage may vary, there be dragons.
https://wiki.preterhuman.net/Macintosh_Monitor_Sense_Codes
If by "standard" you mean Apples' usual cornucopia of nonsense, then yes.
