fallemarg
Hello everyone. I'm not certain that I am in the right place for this, but I am in the process of cleaning my storage of computer items and I came across this monitor. It came to me with a very beat up HP machine several years ago and I just put it into storage without testing it and what not. I found the specifications on the monitor here - http://www.cmcusa.com/htm/product/hardware/mon/mag/dx1595o.htm The whole monitor was in pretty nasty looking condition when I got it and I wasn't even certain the thing would work.
I cleaned it up the best I could and tested it. The monitor has a decent picture. It has dials for brightness and contrast without the little stop (where it stops on in a spot for suggested brightness and contrast. Sorry don't know the actual term for it.) to make it look best. The front of the monitor is yellowed and of a different color than the rest of the frame. The power button must be made from a different material because it is horribly yellow. Someone clearly tried to clean the monitor without proper cleaning materials because the screen is streaked and I don't have any monitor cleaning supplies here that I know of otherwise I would try to correct it. Utilizing Isopropyl cleaning pads and Scrubbing Bubbles on a cleaning towel I managed to get a fair amount of the grime and gunk off of the monitor. It's not perfect and definitely not a show piece, but as far as monitors go it does work if you need a 15" SVGA monitor capable of 1280x1024 resolution. For whatever reason whomever had this before me got rid of the tilt swivel base *grumble grumble*.
Well as I am looking to slim down the items I don't use, and this is an item I don't see myself using, is there anyone out there that wants it? All I ask for is that shipping is covered from here to you. I will pack it the best I can to make certain it gets to you safely. I don't expect shipping to be cheap though, and you will need to let me know what method of shipping you wish to use so I can give as accurate a shipping quote as possible. Please take a look at the pictures below if you are interested and let me know. I understand if no one needs one, I just don't want to send it to the recycle center. If no one wants it here for one week then I will post it over at Amibay where I also post from time to time and see if anyone wants it there. Thank you for taking a look and have a great day!
Kind Regards,
Nathan
-Edit- I apologize in advance if I have posted this in the wrong forum section. Please let me know if I have.
Kind Regards,
Nathan
