About the ONLY thing I hate about images, is using IMD - no offense, Dave! Thanks for the work!
BUT.... I am accustomed for YEARS inusing TeleDisk - it does EVERYTHING automatically for you, and you don't have to remember all the transfer-rate conversions, etc...
Make SURE you read the part in the DOC about the transfer rates (I see the Kaypro 4 .IMD's are 250kbps - make sure that's 360kb DS/DD) and make sure you also set sides to 2, etc...
it ALWAYS drives me nuts to use it - but I understand the need to get past TeleDisk, as it's status is questionable, to say the least. My only issue, is if I don't use IMD for a while, I gotta run back to IMD.DOC, read the transfer rate section, and take notes and relearn all over again <sigh>.
Gotta be me, though, because it IS an awesome imager. It even does Tandy M4/M4p which I traditionally have had issues with using TeleDisk.
The other thing I noticed, is the images Dave has are for the Kaypro 4/84.
I don't know offhand how/if a 4/83 will handle that, if you happen to have one.
Search for kaypro 4 and see if you find my postings on ID, or just post a pic of your K4's mainboard, and I'll tell you what it is.
Basically, if it has the ROM socket in the middle, and it's a 28-pin socket, and has the 50-pin solderholes on the right side, where the FDD and
power go, it should be a 4/84. Also, in a 4/84, the RAM is all nice and neat, in the very left front corner of the mainboard.
T
