Making LDOS 5.3.1 disks from images for the Model I
Al Hartman
Keansburg, New Jersey, United States
After successfully making bootable disks for my Model 4 earlier today, I've turned my attention to making a set of bootable LDOS disks from the images at the Tim Mann Misosys site.
My first attempt failed. Every image when being written had errors under Imagedisk.
I had made blank DMK images under SDLTRS and backed up the contents of the JV1 images to them. That didn't work.
So... I decided to replicate what worked this morning.
I used the instructions on making a double density bootable disk, omitting the double density bits to make a new single density master. Basically, doing a file by file copy.
I also made a double density master, while I was at it.
I'll bring the images over to my 5150 and try writing them later tonight.
So, stay tuned for the results.
Al Hartman
I gave up trying to do it the hard way. I wrestled the 5150 off my kitchen table and set up a 486 motherboard a friend sent.
As it turns out, the 16 bit IDE/FDC controller card I had supports single density disks.
After loading up a hard drive with DOS 3.3, Imagedisk, and several DOS based emulators, I made the LDOS disk directly to a floppy drive. It booted from the floppy in the emulator, so all is well.
Later today I'll figure out how to copy the two CPM diskettes from the Lo-Tech IDE adapter for the TRS-80 to SSDD 40 track disks and make Imagedisk images of them.
Not every Model 4 has double sided drives, and even less Model IIIs have them, unless the owner added them.
