I changed the memory on my Vtech laser xt/3 because had earlier a parity error.
But now i have got 2 problems.
1. I have installed new memory on the 2 inside rows (removed all older), which should give me a total of 512KB if i set sw1 and lever 3 to ON. (didnt installed the optional 128KB memory yet due troubleshooting. that four x 64x4 and two 64x1 parity.
2. I should have 512KB memory installed, but the system now only sees 64KB
3. Also got a memory address error on 00000, 04.. But dont know where this IC is located. Behorehand i tested all the memory chips with the DIY CHRIS 4164/41256 Dram tester from ebay. But this tester, tested all the chips as good..
