S Sega Experienced Member Joined Jun 29, 2013 Messages 92 Jan 23, 2018 #1 I just got a hold of this Microsolutions external parallel Hard drive but is missing the power supply. Does anyone knows what are the specs of the needed Ac adapter? Thanks in advance for any help.
VERAULT Veteran Member Joined Jan 30, 2012 Messages 8,492 Location Connecticut, USA Jan 24, 2018 #3 does it have a barrel jack or something that looks like a ps2 connector?
K krebizfan Veteran Member Joined May 23, 2009 Messages 6,330 Location Connecticut Jan 24, 2018 #4 The Micro Solutions list of power supplies can be found https://web.archive.org/web/2004040...-solutions.com:80/tech_support/docs/2750.html With the model number on the drive, it should narrow down the power supply needed. You may want to move to a different date of the internet archive if your drive was made before the start of the list.
S Sega Experienced Member Joined Jun 29, 2013 Messages 92 Jan 25, 2018 #5 krebizfan said: The Micro Solutions list of power supplies can be found https://web.archive.org/web/2004040...-solutions.com:80/tech_support/docs/2750.html With the model number on the drive, it should narrow down the power supply needed. You may want to move to a different date of the internet archive if your drive was made before the start of the list. Click to expand... Great thanks much that helped a lot and the drive is alive an running :thumbsup:
