Hi,
I bought a Model 1 system on eBay recently, and it has a lower case mod.
I assume it is an Electric Pencil equivalent - but not sure.
In the auction pictures, it showed it running LDOS just fine with lower case - and considering how well the system was packed, I have no doubt the pictures are accurate.
After I received it, instead of immediately plugging it in and verifying everything, I instead decided to perform a power supply re-cap on it.
And since I had it open and it had the original interconnect cable, I just couldn't resist replacing the cable with a spare 40 pin one I had laying around.
(removed the cable and installed 20 pin RT angle headers - which the 40 pin cable plugs into)
When I was finished with the mods, I powered it up - and was greeted with a screen where all of the space characters are " ' " and other random gibberish.
It reminds me of how my original model 1 would behave in Level II BASIC when I had lower case enabled via the usual SPDT toggle switch.
This install doesn't have a toggle switch, so I was assuming it would be fine under LDOS - just like in the auction pictures.
I booted LDOS and well - no difference.
I also tried booting NewDOS 80/V2 and issued the command to enable lower case, but that made no difference either.
I tried a simply FOR-NEXT loop under BASIC to poke 0-255 into video memory and it looked reasonable, but I can't recall if the character set is supposed to repeat like I saw.
(Unfortunately it's all powered down and opened up so I can't re-do that test tonight and take a picture)
I'm pretty sure the fault is mine - but I'm not sure where to look.
If I'm doing it correctly - there should be a couple pictures attached to this post...
One showing a shot of the screen, and another showing the LC mod.
