Agent Orange
I'm wondering if anyone has been successful in installing a 3.5" floppy in the drive (0) or (1) slot.
Yes it works fine, you need a new data cable with all the teeth in place, power adapter cables, a drill to put new holes in the disk drive mounting frame (you'll see when you pull your 4P apart). Before you mount everything up you need to set the 3.5" floppy as a 2nd drive, boot from a traditional 5.25" LS-DOS disk and make a bootable 3.5" diskette. The reassemble the system and boot from that floppy disk.
Ian.
I've got one of those available if anyone is currently looking for one.I was lucky to find (a long time ago, in an old PC-XT) a 5.25 -> 3.5 adapter, which has a card edge connector on one side and the usual 34 pins floppy connector on the other side, so I can put any 3.5 drive and "it just works".
Here are 2 pictures of my 4P. I was lucky to find (a long time ago, in an old PC-XT) a 5.25 -> 3.5 adapter, which has a card edge connector on one side and the usual 34 pins floppy connector on the other side, so I can put any 3.5 drive and "it just works". (on my other TRS80, I modify TEAC 3.5 drives by removing one resistor and they also work with straight cables. for those in the Bay Area, there are still a couple of these drives at Weird Stuff (Sunnyvale), $3 or $4 each...)
View attachment 16255View attachment 16256
