I've got a temperature related issue that screws up the timing on everything in the system. It starts with video slowly getting out of whack, then the whole thing dies. Either cold spray or power off for a few fixes it. Actually the FDC starts to get wonky first and I haven't looked to see where it gets its signal from since its not managed by U126, just CPU/Video/RS232. There is a capacitor and a resistor in this circuit that I'll check as well.
I have narrowed it down to either the 20.2752 MHZ oscilator or U126 (PAL). It's really hard to ensure I don't get cold spray (I use compressed air) on both so I'm not 100% sure its the crystal or the PAL for that reason. It is 100% a temperature issue I know that because the system works great for about 5 minutes then things start failing eventually video smears and system lock up occur at the same time.
If this is the PAL the system is toast unless someone has cloned it. Can oscillators be temperature sensitive? I guess it could be a broken seal on Y1.
I'll eventually get the scope out and report if the 20mhz signal is drifting as it warms up, since more than just video goes bad I'm really suspecting its U126, a 16R6A PAL or the source to it. There are a few support items that could be failing too, will report out what I find.
