Model A 5150 motherboard refurbishment #2
pkhoury
Bandera, TX
Just need some assistance for an otherwise working board that I was working on, to remove corroded memory sockets and slot #2 on the ISA bus. Another friend advised I should remove these sockets, as they had remnants from a RTC battery that leaked before I got the board.
Problem #1:
  • What is the capacitance of the memory ceramic caps? From what I read, it says K5M 473, which I'm guessing is 43pF? Anything else I need to pay attention to?
Problem #2:
  • I pulled a few traces from the top of the motherboard that connect ISA sockets 1 and 2. Can I get away with soldering some rework wires to bridge those lines together on the underside?
  • Getting out the ISA socket was a real pain in the ass.
See the 'Capacitor Tolerance Letter Codes Table' section of [here], where '473' is actually given as an example.
No polarity.
Voltage wise, some are on the +5V line, some are on the -5V line, and some are on the +12V line. The technical reference for the early IBM 5150 indicates "15VWDC", which is 15V DC working voltage. There should be no issue is using a higher rated voltage.
I cannot see why not.
I did it at [here].
I did it at [here].
LOL; yes you did! That gives me hope, because I was hoping to keep this board as a spare.
I need to grab a photo, but I bought an otherwise worthless XT clone at VCFSW JUST for the power supply - early black 5150 supply with nuts on top and IBM part number (which would get paired with this board).
Another question relating to a 5160 (but while it's on my mind); and yes, I did read your site and other comments on other threads. Just to be clear - I should be fine using 2 legged tantalums on a motherboard with 3 legged, so long as I do polarity correctly, right? As I understand it, negative, positive, negative, right? On the board in this thread, I already recapped it just to be on the safe side.
I wonder if that chipquik low melt solder usually used for SMD component removal would be useful for removing parts from these boards too.
Correct, and on an IBM 5160, done per option 2 at [here].
Technical: One intended use of three-legged capacitors is shown at [here]. In the IBM 51xx series, IBM have not wired things that way.
Yes, for the IBM 5160, the hole pattern in the PCB is negative-positive-negative, irrespective of whether the capacitor is filtering a positive or negative voltage.
That is an IBM 5150 motherboard. Things can be different:
5150 motherboard of type 16KB-64KB: Per [here], only uses 2-legged capacitors.
5150 motherboard of type 64KB-256KB: Same situation as the IBM 5160.
