misterblack
Hi guys, I recently picked up a boxed Monitor IIc and stand to match my Apple IIc. (I have very fond memories of spending countless hours a day using my Apple IIc when I was a kid, so yes, trying to recreate this.)
I was happy when I received the monitor in that, other than yellowing, it's in fantastic shape. I'm at the office so can't properly test, but a quick smoke test shows the power LED lighting up normally but HV and the heater doesn't appear to come on. I took a moment to open up the monitor and all seems normal inside (nothing obviously broken) ... and what's nice is it's very clean inside, no telltale signs of high number of hours.
Anyway, I have downloaded and printed out the SAMS for the monitor, but was wondering if anyone has any tips of things to look for immediately.
I recall my monitor when I was a kid had a bad solder joint leading to flaky video signal -- so I will take this apart and look for these. Looking at the schematics, I also see the power LED is run off the 12v power rail, which leads me to believe the power supply (And fuse) is good. But I do see the flyback and heater all appear fed from the same source from the power supply. (Source 4 on the SAMs)
Thanks for any tips you can give!
