Monitor/TV cable for Apple iic?
gladders
London
Hi all,
I'm in the UK, and recently acquired a lovely (if slightly yellowed) Apple iic, accompanied with a separate 3.5" drive and US power supply.
I'm trying to hunt down a cable to run it with. I have a small LCD TV with a 'PC' port, but it also has the usual other European plugs including SCART.
I've looked on eBay but video cables seem rare and hard to come by. Can it be confirmed that the iic uses the same video cable as the ][ and iie? Are there any decent TV signals (would rather avoid composite unless it's the only option)
I've seen VGA converters, but Christ they're dear!
Thanks everyone :)
yes the standard video output is composite so any yellow shielded RCA cable will work (technically any cable will work but you loose a bit of definition using unsheilded non 75 ohm cable)
Hello,
Plamen's (a2heaven) VGA adaptors are great. I have bought one for my //e.
You can also try to find the Chat Mauve SCART cable like this one. But it's pretty rare and pricey.
