FishFinger
When using mono text mode (mode 7) on an MDA, Hercules, or an EGA card set up for mono then text is displayed at two intensity levels, and the full range of attributes is supported - bright, inverse, underline.
I've tried this on a few VGA cards, and none of them seem to handle this mode correctly. None of them support the bright intensity level, and some don't do inverse or underline either, so you just get plain text no matter what attributes are set.
Is there a driver that needs to be loaded for better mono mode emulation, or is it something VGA cards just don't do?
