gnupublic
Hello,
the summer is heating the town, it's too hot for the minis in the flat, so I tried something with mico PDP11/73.
My PDP11/73 came with an MTI MLV11M controller together with a Rodime RO204 disk as bootdisk. The rodime had problems from the beginning on with booting, but when it came to temperature after 20 minutes, it did. I was able to save the RT11 on it in 2019.
Meanwhile the Rodime has passed away after a longer time period of getting more and more errors. So I wanted to replace that disk against another MFM disk.
I did some googling, but did not find any informations nor documents for the controller how to do it. Just 2 things:
- someone was (long time ago) searching for a file (rl02dg.sav) for this controller. Nobody replied.
- And somebody said that this controller would emulate multiple RL02 for the system.
On the RT11 of the Rodime, I found the file rl02dg.sys. So I started this file with "r rl02dg.sys" and was happy this is the program for testing and formating disks with this controller.
So I did. The controller only formats, if ECC is disabled and I took some time to find out the jumper for ECC. There is now way to configure the disk in any way, you can just format it. When this is done, you can do an ".INIT/BADBLOCK DL0:" in RT11 and use this disk. It's 10MB big like expected for RL02. So with a 20MB MFM disk I expect 2 RL02 disks. DL0: and DL1:.
But if Itry to access DL1:, the System hangs. No matter if I do an INIT or DIR. I tried with different disks up to 40MB, but always the same. When accessing DL2: or DL3: I get an error message, but DL1: always hang.
Disks I used: ST-225, ST-125, NEC 3142
Does someone here has further informations for this controller? Any hints?
Have fun,
Volker
Have fun,
Volker
