PG31
After a couple of busy weeks in work I've returned to this project. Thanks to TasKing for the SD RT-11 image. I can confirm this boots from the CMD CQD and SCSI2SD in my BA23 11/53 with no issue. If I put the SCSI card with SCSI2SD and SD card with RT-11 on in my 11/02 with MXV11 it doesn't boot although I can run the inbuilt SCSI utility on the CMD CQD. From advice I believe the 16K on the MXV11 isn't enough to boot the RT-11 image that I have. I have a spare M8044-DK MSV11 (status unknown) card so I thought that I'd add this card into the mix. I wanted to keep one slot to add networking but heh ho!. As this is the second memory card now, I've tried different switch configs from the manual and I can't get to the ODT prompt with this card in the system. I also have a DLV11-J (status unknown also) and I removed the MXV11, confirmed the DLV11-J is at base address and added this to the system with the MSV11 set at base address and I don't get the ODT prompt. I'm not sure if both cards are faulty or if I'm configuring something wrong or if I have an incompatibility. It would have been cool if this backplane was five or six dual slots and not four
