My 386 with WIN 95
Agent Orange
SE MI
Decided to install Norton Utilities for Windows 95 today on my 386. As a prerequisite, you need a qualifying program, such as Norton Desktop Utilities for DOS 1.0, which I have and installed same with no issues. I have two complete sets of NU for W95 and am having a problem with the install on Setup Disk #3. The disk won't unpack from either set. I wondering if anyone has run into a similar problem with while attempting to setup NU for W95? Disk 3 is loaded with DLL's and it would be a real PITA to have to install all of those files manually. I'll do what ever it takes, but I sure would like to get to the bottom of the unpack problem.
FWIW, I have *two* sets of ~8 disks each of that program and all of the disks are bad and have been for almost ten years! :)
When I think about, that may be a reason that it was setting on the shelf in pristine condition. I don't think I ever got it up and going back in the day. I would like to get it to install just because. However, I have a ton of other stuff like PC Tools, etc., that I can make do with.
Are the disks themselves readable? Depending on the setup program and if you have enough hard disk space, you might be able to copy the contents of the disk in to a single folder and run setup from there.
Also, which version of Norton Utilities for Win95 is this? 1.0? 2.0? (There is a similar Norton Utilities for Windows 95 2.0 upgrade floating around if that could help compare/fix the files) Normally, I recommend Norton Utilities 2001 which is the last to support 95, but that might not work well on a 386 :)
The disks, computer, HD, space, etc. are all fine. It's Norton Utilities for Windows 95 period - no version number. My previous post indicated that it would not unpack after disk #2 - disk #3 is readable but the unpack routine is flawed. There is a bug in the setup. I'm looking for the easy fix. Thanks for taking the time to respond. BTW, total of 8 GB in four 2 GB partitions (ONTRACK Dynamic Drive Overlay V9.57 © 1993-2002).
Easy fix: find the slightly later version that was on CD.
Are you using the NU installer or trying to uncompress the files directly? I vaguely remember that Norton used its own compression routines that don't match the routines in Win95.
It's the 3-disk set on 1.44 floppy's. I don't think it was ever released on CD - may be wrong about that. 1st & 2nd disks install okay via Norton, 3rd disk won't unpack. I may try to expand the files on the 3rd disk manually and see what happens. Weird that 2 different program sets have the same problem.
Hi Agent Orange,
I have that NU for Win95. Its on three 3.5" HD floppy disks, as prerequisite one needs to have disks for some older NU, and it's the 1'st version for Win95. Files are dated 8/3/95. I think we are talking about the same thing?
I have installed it once, and there were no problems with the installation. At some point I had to put in the 1'st disk of NU 6.01 for DOS, when the installer software asked proof, that I was eligible for update.
BTW, NU for Win95 Version 1 was also available on CD-ROM. I have it on this computer. It's files are dated 2/15/96. Version 2.0 is different thing, it supports FAT32, has some other added features too(I think), and its clearly marked V 2.0.
Run a Disk Test on the third disk(s). You may find (as I did) that the disks, themselves, are hosed, and if that's the case nothing will unpack them because the oxide coating on the surface is shot. Do these third disks foul your floppy drive when you try to read them? If so, they're definitely shot and nothing will recover them. If they don't foul the drive's heads when you run them you should be able to get to the data on them somehow.
The drive is okay. I downloaded the whole package from VetusWare with the same results on disk #3. I'll fire up my DOS laptop and see what happens. In the meantime, I going ahead and installing version 3 off of a CD.
That is just weird. Looking at the one from Vetusware, all of the files that end in "$" are actually PKZIP files. Testing them using pkzip, the files NUDESK.HL$ (NUDESK.HLP) on disk 2 and SYSINFO.VX$ (SYSINFO.VXD) on disk 3 have CRC errors, but extract anyway.
Are the files on your original disks identical to these?
Are these the same or different files that give you errors on your original disks?
The files will extract anyway, but SYSINFO.VXD extracts to the wrong size, and is presumably corrupt.
They really shipped corrupted disks to everyone? :confused6:
I only used disk #3 from Vetusware and it turns out that the file set is on their disk #3 is 26.5K larger than the OEM set. I think I figured out why. Who ever compacted the Vetusware disks didn't adhere to the OEM order, just took into consideration of how to cram all the files onto 3 disks. Anyway, the Vetusware disk #3 died about half way though the install. So, that's going to be another project to figure out what the heck is going on. I had a CD .img of version 3 and it turned out to be in German. I think the easiest way will be to expand all of the files and put them on a CD. The only problem with that is that you are dealing with 2 directories: c:\Program Files\Norton Utilities\Symantec & c:\Program Files\Norton Utilities\Shared. If someone has Norton Utilities for Window 95 (no version number on the disks) installed and running, it would be nice to see a file listing. BTW, I didn't get any 'errors' using the OEM disks, just wouldn't expand disk #3.
Hi,
I can post here a directory listing of my Win95 computers NU directories, it has NU for Win95 v.1 CD-ROM version installed and running.
But if you prefer the version1 from floppies, would you have liked to have disk image of that #3 floppy?
Hi,
Here are directory listings of my Norton Utilities for Win 95 V.1 installation. BTW, I have three directories, C:\program files\Norton utilities\System and C:\program files\Symantec.
Volume in drive C has no label
Volume Serial Number is 1533-1F0C
Directory of C:\Program Files\Norton Utilities
. <DIR> 01-03-15 5:51p .
.. <DIR> 01-03-15 5:51p ..
SYSTEM <DIR> 01-03-15 5:51p System
SD32 EXE 379,392 02-15-96 9:00a SD32.EXE
DISKS INF 20,184 02-15-96 9:00a DISKS.INF
NUPIPLIN DAT 10 02-15-96 9:00a NUPIPLIN.DAT
PIPELINE INI 444 02-15-96 9:00a PIPELINE.INI
MAILBUSI CTL 2,243 02-15-96 9:00a MAILBUSI.CTL
END-USER TXT 5,813 02-15-96 9:00a END-USER.TXT
SIWFMOD EXE 5,088 02-15-96 9:00a SIWFMOD.EXE
SIWPIPL EXE 60,096 02-15-96 9:00a SIWPIPL.EXE
SUNZIP32 DLL 40,448 02-15-96 9:00a SUNZIP32.DLL
README TXT 35,502 02-15-96 9:00a readme.txt
INSTALL INF 41,926 02-15-96 9:00a install.inf
SIWDLL32 DLL 76,288 02-15-96 9:00a SIWDLL32.DLL
SETUP EXE 42,144 02-15-96 9:00a setup.exe
PIPELINE DLL 141,312 02-15-96 9:00a PIPELINE.DLL
INST32 EXE 370,176 02-15-96 9:00a INST32.EXE
SIWNU DLL 847,360 02-15-96 9:00a SIWNU.DLL
RESCUE EXE 251,590 02-15-96 9:00a RESCUE.EXE
NDD32 EXE 485,376 02-15-96 9:00a NDD32.EXE
UE32 EXE 477,184 02-15-96 9:00a UE32.EXE
SI32 EXE 1,061,376 02-15-96 9:00a SI32.EXE
NDIAGS CF 1,561 02-15-96 9:00a NDIAGS.CF
NDIAGS SG 1,561 02-15-96 9:00a NDIAGS.SG
NDIAGS UK 1,561 02-15-96 9:00a NDIAGS.UK
NDD HLP 26,331 02-15-96 9:00a NDD.HLP
NDIAGS SND 55,721 02-15-96 9:00a NDIAGS.SND
UNINSTAL INF 47,702 02-15-96 9:00a UNINSTAL.INF
IMAGE32 EXE 87,552 02-15-96 9:00a IMAGE32.EXE
NDIAGS HLP 104,404 02-15-96 9:00a NDIAGS.HLP
RESCUE32 EXE 148,992 02-15-96 9:00a RESCUE32.EXE
NDIAGS EXE 291,652 02-15-96 9:00a NDIAGS.EXE
RESCUED HLP 8,124 02-15-96 9:00a RESCUED.HLP
UNFORMAT HLP 11,237 02-15-96 9:00a UNFORMAT.HLP
SYSDOC32 EXE 17,920 02-15-96 9:00a SYSDOC32.EXE
UNFORMAT EXE 394,226 02-15-96 9:00a unformat.exe
NDD EXE 575,202 02-15-96 9:00a ndd.exe
DISKEDIT ICO 766 02-15-96 9:00a DISKEDIT.ICO
DISKEDIT PIF 967 01-03-15 5:51p DISKEDIT.PIF
NDIAGS ICO 766 02-15-96 9:00a NDIAGS.ICO
NDIAGS PIF 1,070 01-03-15 5:51p NDIAGS.PIF
UNERASE HLP 31,744 02-15-96 9:00a unerase.hlp
DISKEDIT HLP 89,382 02-15-96 9:00a diskedit.hlp
UNERASE EXE 570,834 02-15-96 9:00a unerase.exe
DISKEDIT EXE 602,578 02-15-96 9:00a diskedit.exe
DIRLIST 0 03-10-15 11:22p dirlist
44 file(s) 7,415,805 bytes
3 dir(s) 868,253,696 bytes free
Directory of C:\Program Files\Norton Utilities\System
SDVXD VXD 4,164 02-15-96 9:00a SDVXD.VXD
NUTHK16 DLL 10,048 02-15-96 9:00a NUTHK16.DLL
SD32ENG DLL 129,024 02-15-96 9:00a SD32ENG.DLL
NDDBMP32 DLL 458,240 02-15-96 9:00a NDDBMP32.DLL
USHELLEX DLL 375,296 02-15-96 9:00a USHELLEX.DLL
S32GUI8 DLL 361,472 02-15-96 9:00a S32GUI8.DLL
SENSOR32 DLL 378,880 02-15-96 9:00a SENSOR32.DLL
PGNORTON DLL 474,624 02-15-96 9:00a PGNORTON.DLL
SYMMTHK8 DLL 2,832 02-15-96 9:00a SYMMTHK8.DLL
S32DMAP8 DLL 32,256 02-15-96 9:00a S32DMAP8.DLL
UEPROC32 EXE 31,232 02-15-96 9:00a UEPROC32.EXE
UE32 HLP 57,377 02-15-96 9:00a UE32.HLP
S32FMT8 DLL 44,032 02-15-96 9:00a S32FMT8.DLL
S32SYS8 DLL 49,664 02-15-96 9:00a S32SYS8.DLL
NUDESK HLP 135,920 02-15-96 9:00a NUDESK.HLP
NDD32 HLP 98,430 02-15-96 9:00a NDD32.HLP
RESCUE32 HLP 50,975 02-15-96 9:00a RESCUE32.HLP
SD32 HLP 103,428 02-15-96 9:00a SD32.HLP
UEBMP32 DLL 224,768 02-15-96 9:00a UEBMP32.DLL
S32NPT8 DLL 59,392 02-15-96 9:00a S32NPT8.DLL
SI32 HLP 113,563 02-15-96 9:00a SI32.HLP
SYSINFO VXD 832,404 02-15-96 9:00a SYSINFO.VXD
SYSDOC32 HLP 195,094 02-15-96 9:00a SYSDOC32.HLP
NWCALLS DLL 146,544 02-15-96 9:00a NWCALLS.DLL
NUMISC DLL 271,360 02-15-96 9:00a NUMISC.DLL
S32MTHK8 DLL 16,384 02-15-96 9:00a S32MTHK8.DLL
USHELLHK DLL 15,872 02-15-96 9:00a USHELLHK.DLL
IMAGE32 HLP 29,892 02-15-96 9:00a IMAGE32.HLP
NUTHK32 DLL 20,992 02-15-96 9:00a NUTHK32.DLL
S32MAIL8 DLL 21,504 02-15-96 9:00a S32MAIL8.DLL
DISKEDIT REG 108 02-15-96 9:00a DISKEDIT.REG
IMAGE32 REG 388 02-15-96 9:00a IMAGE32.REG
INFODESK ICO 1,078 02-15-96 9:00a INFODESK.ICO
NDD REG 103 02-15-96 9:00a NDD.REG
NDD32 REG 380 02-15-96 9:00a NDD32.REG
NDIAGS REG 106 02-15-96 9:00a NDIAGS.REG
NPROTON REG 710 02-15-96 9:00a NPROTON.REG
RERUN REG 192 02-15-96 9:00a RERUN.REG
RESCUE32 REG 392 02-15-96 9:00a RESCUE32.REG
REVXD REG 208 02-15-96 9:00a REVXD.REG
SD32 REG 376 02-15-96 9:00a SD32.REG
SHARED REG 101 02-15-96 9:00a SHARED.REG
SI32 REG 381 02-15-96 9:00a SI32.REG
SPACEWIZ REG 108 02-15-96 9:00a SPACEWIZ.REG
SW32 REG 382 02-15-96 9:00a SW32.REG
SYSDOC32 REG 392 02-15-96 9:00a SYSDOC32.REG
UNERASE REG 107 02-15-96 9:00a UNERASE.REG
UNFORMAT REG 108 02-15-96 9:00a UNFORMAT.REG
UNNU REG 394 02-15-96 9:00a UNNU.REG
UNPROTCT REG 214 02-15-96 9:00a UNPROTCT.REG
NDRVEX REG 3,707 02-15-96 9:00a NDRVEX.REG
NU REG 3,505 02-15-96 9:00a NU.REG
VSENSOR VXD 5,270 02-15-96 9:00a VSENSOR.VXD
NPROTECT REG 2,892 02-15-96 9:00a NPROTECT.REG
RESCUE32 INI 4,145 02-15-96 9:00a RESCUE32.INI
DIRLIST 0 03-10-15 11:23p dirlist
56 file(s) 4,771,410 bytes
2 dir(s) 868,220,928 bytes free
Directory of C:\Program Files\Symantec
NPROTECT VXD 27,732 02-15-96 9:00a NPROTECT.VXD
SYMEVNT1 DLL 3,984 02-15-96 9:00a SYMEVNT1.DLL
SYMKRNL8 VXD 6,893 02-15-96 9:00a SYMKRNL8.VXD
S32EVNT1 DLL 16,384 02-15-96 9:00a S32EVNT1.DLL
S32STAT DLL 23,552 02-15-96 9:00a S32STAT.DLL
NUDESK CNT 18,443 02-15-96 9:00a NUDESK.CNT
SYMEVNT 386 99,895 02-15-96 9:00a SYMEVNT.386
S32FAT8 DLL 100,864 02-15-96 9:00a S32FAT8.DLL
S32KRNL8 DLL 150,528 02-15-96 9:00a S32KRNL8.DLL
INFODESK DLL 250,368 02-15-96 9:00a INFODESK.DLL
INFODESK HLP 39,331 02-15-96 9:00a INFODESK.HLP
SALTHK32 DLL 16,896 02-15-96 9:00a SALTHK32.DLL
TKKE328 DLL 18,432 02-15-96 9:00a TKKE328.DLL
SYMGLOSS HLP 112,780 02-15-96 9:00a SYMGLOSS.HLP
INFODESK CNT 1,304 02-15-96 9:00a INFODESK.CNT
S32UTIL8 DLL 123,904 01-03-15 5:51p S32UTIL8.DLL
SYMKRNL8 DLL 127,200 02-15-96 9:00a SYMKRNL8.DLL
TKKE168 DLL 4,832 02-15-96 9:00a TKKE168.DLL
SALTHK16 DLL 3,888 02-15-96 9:00a SALTHK16.DLL
SYMANTEC CNT 21 02-15-96 9:00a symantec.cnt
21 file(s) 1,147,231 bytes
2 dir(s) 868,188,160 bytes free
