In the IBM 83-key keyboard, the
green coloured wire was used for hardware reset functionality, but only the early version of the 83-key keyboard needed to be reset by the motherboard circuitry.
Strangely, IBM still included this reset wire in some later 83-key keyboards, even though the keyboard did not use the reset wire.
Maybe in your 101-key keyboard, IBM (or whoever made it) did not include the reset wire (i.e. not needed/used).
The 'silver' wire in your cable
appears to be connected to the metal foil in the cable. That foil acts as an RF shield, and is usually grounded at at least one end of the cable. For
example, in the IBM 5153 cable end shown at [
here], the shield is grounded via the connection to pin 1. I think that one of the other wires is the ground wire, and you should be able to see if that is the case via use of a multimeter in resistance mode.
