My Incoming IBM PC 5150
Great Hierophant
Massachusetts, USA
Although it cost alot, I will finally have an IBM PC 5150. I also will have the following hardware to fit inside it:
IBM Personal Computer Math Coprocessor
IBM Keyboard (83-Key)
IBM Monochrome Display
IBM Monochrome Display and Printer Adapter
IBM Color Display
IBM Color/Graphics Display Adapter
IBM Printer Adapter
IBM Asychronous Adapter
IBM Game Control Adapter
IBM 5-1/4" Diskette Drive Adapter
IBM 5-14" Diskette Drive x 2 (Full Height)
IBM 20MB Fixed Disk Drive
Kraft Premium II PC Joystick (substitute for IBM PCjr.'s joystick)
I am missing the following still:
IBM 64/256K Memory Expansion Option x 2 (to get to 640KB)
IBM Asychronous Adapter (2nd)
IBM Fixed Disk Drive Adapter (20MB Compatible Version)
IBM 20MB Fixed Disk Drive (2nd)
Obviously, all of this will not fit inside a 5150, with its 5 slots and 63.5W power supply! Until I can afford an IBM Expansion Unit, that is the way it will have to be! The end result is that I will have a fully stocked IBM PC 5150, going as far as it can go with IBM hardware.
tezza
New Zealand
Well done,
The 5150 is a classic machine and that is a pretty full configuration.
I'm looking for a monochrome (green screen) monitor in good condition here in New Zealand but I'm not holding my breath.
Tez
per
Western Norway
I only got the following in my XT:
1x IBM Personal Computer Math Coprocessor (Not really the IBM one, but from Intel)
1x IBM Keyboard (83-Key)
1x IBM Monochrome Display
1x IBM Monochrome Display and Printer Adapter
1x IBM 5-1/4" Diskette Drive Adapter
2x IBM 5-1/4" Diskette Drive (Full Height)
1x IBM 64/256K Memory Expansion Option
Where do you get all that other stuff from?
nymetropolitans
LI NY
Sweet, that must have set you back a few!!
The color monitor/adapter...is that CGA or some other kind of color graphics? My local library used 5150s up until pretty recently, but they only had monochrome monitors. Never seen one (in person) with a color monitor hooked up to it.
frozenfire75i
Banned
~I AM NO LONGER A MEMBER OF THIS FORUM~
Congrats, And welcome to the wonderful world the IBM 5150 PC.
IBM Color Display
IBM Printer Adapter
Great Hierophant
Massachusetts, USA
It is here at last and appears to be working perfectly. I say "appears" because there is much testing still to be done. I have been able to boot to DOS, read/write off both drives and even play some King's Quest II (booter) and other games.
It even came with an unexpected bonus: an AST Six Pak Plus card! With it I have the full 640K of RAM and an extra Serial, Parallel, and a replacement Game port.
Unfortunately, the analog stick on my Kraft II isn't working correctly. Maybe the pots need some cleaning.
