As far as I know RSX-11M Plus (starting from Version 2.1) checks if the machine has unibus mapping registers and then uses UMR for controllers that normally support only 18-bit. Even on Q-Bus machines. And a nice side effect of Version 2.1 is that when they encounter a RH controller with a Massbus Address Extension then they deactivate the UMR for RH controllers and use 22-bit addressing, so you could use a "RH70" on a Q-Bus machine (e.g. the Emulex SC03 ESDI Controller).
