Specs of my baby, named Voodoo:
FIC VA-503+ Motherboard
(extensive tweaking, USB, PS/2 Mouse, AT keyboard, SIMMS/DIMMS both supported, AT/ATX power both supported - best BIOS installed, tried later, unstable, reverted - never changing it again)
512MB DRAM
(2x256, a miracle I found sticks of that at PC100.. or 133 clocked down? Either way, pin-compatible.. :D)
Intel Tillamook 266Mhz overclocked to 300Mhz, 100x3Mhz - 1:1 RAM!
(Pentium Mobile, this one converted by somebody in China - thank you China! :D)
Matrox G250 AGP 2x 8MB
(I have an 8MB SIMM for it which I may use.. this card supports 1080p but also scales back to Win3x drivers.. :D)
Voodoo 2 PCI 8MB by Diamond (I hope to have two in there some day)
SB16 Value (I love the value version, the PnP always works nicely..
Cisco Aironet 350 PCI 802.11b Wireless (has DOS, Win3x, 95, 98, etc..)
Promise 133TX2 PCI IDE Controller (ATA133, two channels, works in addition to mobo controller, though I disable that anyway)
120GB HDD (I tried for 750GB, controller bugged writing past a certain point, came w/ a 200GB disk, so it's a bit old for that size it seems even tho it recognized it - even with an overlay, which I don't think comprehended it either, lol)
3.5"/5.25" combo FDD (the 5.25" is also slot loading like a 3.5")
Slot-loading DVD drive
ZIP-250
LS-120
Disney Sound Source
CTX 17" CRT
IBM Model M w/ Silver Badge
IBM PS/2 Oval Mouse w/ Grey Buttons
(sometimes I use original PS/2 mouse, sometimes newer NetScroll.. always IBM though. xD)
3dfx Case Badge (an important component, of course)
It's a smaller AT form factor, dunno technically, but I think it's Baby AT..? Using a smaller-than-mid case, or I'dve crammed more 5.25" and HDDs in.. I have a 5.25" speaker that Id've liked to put in there, heh.
Smooth as silk, has run up to 98SE before, currently working on getting Win3x up and running w/ all the stuff, Windows likes to just exit to DOS (and then crash DOS if you try to use it for long) at the moment - quite odd. Will be fixing that soon enough..
512MB DRAM
ZIP-250
LS-120
Disney Sound Source
CTX 17" CRT
