PgrAm
Hey all I've been experimenting on different ways to implement transparent sprites in mode X and I came up with a method that I haven't seen before so I thought I might share.
The image is stored in a standard planar format, with palette index zero representing a transparent pixel, and blitted in the following manner:
The outer parts are psuedocode because the code I wrote this for is complicated in a way that isn't really relevant here. The interesting idea is generating a mask based on the pixels value and using the vga card mask to avoid branching. This could also work with a pre-computed mask but I didn't really want to waste the memory for that in my application.
Advantages:
- No branching required
- clipping is fairly straightforward
- can be stored in the same format as opaque sprites
Disadvantages:
- Reads the each pixel twice, I tried keeping the data around in a register but juggling registers made it slower on my target (286) but might be worth it on 8088.
- Requires an out instruction for each pixel, slow on protected mode 386/486
Well that's the gist of it, I'm curious to hear what you guys think of it or if there are any improvements you can think of?
outb(SC_INDEX, MAP_MASK);
for each plane:
mov cx, VGA_SEGMENT
mov es, cx
lds si, planeData ;the bitmap data
mov ah, planeMask ;the bit mask to enable this plane
mov bx, bmpHeight ;image height
mov dx, SC_DATA
rowLoop :
mov cx, bytes_per_line ;load the pixel counter
pixLoop:
xor al, al ;AL = 0
cmp al, ds : [si] ;if ds:[si] > 0 CF = 1 else CF = 0
sbb al, al ;AL = 0 - CF, AL = 0 if 0, 0xFF if 1
and al, ah ;combine with the plane mask
out dx, al ;output the new mask setting
movsb ;plot the pixel
loop pixLoop ;continue as long as there are pixels left
add si, lineDiff ;add the remaining distance to the edge of the bitmap
add di, screenDiff ;add the remaining distance to the edge of the screen
dec bx ;continue as long as there are rows left
jnz rowLoop
Advantages:
Disadvantages:
