Hello Friends,
I'm at my wits end here and I could really use some guidance. I just recently bought a NEC Powermate 286 from Ebay and I can't seem to get it to boot from any kind of media. Here is the background:
Thanks in advance,
LCDRUgo
- BIOS chips say V 3.10.02
- The machine came with a 1.44 Mb 3.5" drive. I tested it in another machine and it works fine. I also plugged in a 1.2 Mb 5.25" drive that I had lying around and it also works fine in other machines. But neither drive can boot or read a disk in the Powermate. When I attempt to do so, the drive lights and spins for 5-6 seconds before stopping or it stays lit and spins forever.
- The disks I am using were made from images found on VOGONS, archive.org, and WinWorld.com. I use either WinImage or M. Brutman's DskImage to write the media (depending on whether I'm writing to 3.5 or 5.25 media). All of the disks are bootable and readable on my 386, (even though it complains that there are system hardware differences and that I should run SETUP). None of them boot up my Powermate. I have been exclusively using disk images that are labeled either NEC OEM or "For Powermate".
- I've also tried booting from a CF card in a XT-CF adapter. I am using a 128 Mb card using BIOS HD number 45 for the drive geometry. I get the card ready in my 386 by booting the machine with the NEC HW Setup disk and using it to create a "Large NEC Partition" and then copying the system files to it. Once finished, the CF card boots my 386 just fine. However, when I put it in my Powermate it gets as far as "Booting C >> C" and then halts with a "Missing Operating System" error.
- If it matters, I should point out that the battery is dead. I've tried doing this process with the dead battery both plugged into the motherboard and unplugged. The battery isn't manufactured any more, of course, but I may have found a suitable replacement and I'm waiting for it to arrive in the mail.
Thanks in advance,
LCDRUgo
