Midwest Need a floppy cable for an 8" drive (50-pin)
Covers: North Dakota, South Dakota, Nebraska, Kansas, Minesota, Iowa, Missouri, Wisconsin, Illinois, Michigan, Indiana and Ohio
nullvalue
Indiana
Need a cable for an 8" floppy drive. Edge connector at one end and dual row pin header at the other end. 1 or 2 positions will work, length doesn't matter too much - ideally 2-3' since its for self-contained enclosure. Let me know if you have a spare you'd part with. Thanks!
I thought about making my own.. I've made my own IDC ribbon cables before (using a vice) - but do you know where I'd source the edge connector part?
Are they male/female pin header or edge connector? I have several 8" drives but havent worked on them yet. All inside thier perspective machines.
Just curious. I was going to get into 8" floppy production. How do you intend to power the unit (which are all AC power I believe) by the computer chassis or are you adding your own power?
so one side is edge one side needs to be 50 pin female.. ok plenty of choices,, this for example: https://www.ebay.com/itm/270844905708
Perfect.. and if I want to make it a 2-position cable, 8" drive don't require a twist right? and drive position on the cable doesn't matter since it's driven by Drive Select (DS 1-4) at the drive level, correct?
With the 8" drive I honestly cant confirm that. Youd need to get that from someone more in the know. I thought drive select was done on the drive mechanism.
Oh, if so - can I be your first customer? I still have no idea how I'm going to bootstrap this machine (or whether it's even possible) to format and create a CP/M disk. The chassis I'm using has 2 power supplies for 8" drives built into it. It's a cool chassis, unfortunately it's missing the cover so I may look for a new home for it if I can find another S100 chassis with room for at least 1 8" drive inside.
Here's the power supply. Note the 2 upright PCB's. Those take the DC output from the caps and coverts it to 24V & 5V on the 6-pin power connectors. It also takes a 120VAC lead. So my drive requires both DC & AC.
My method doesnt seem to difficult. Watching Petes video here:
I bought the Dbit 34 pin to 50 pin adapter. And I intend to connect the 34pin ribbon to a Dos machine and run Dave dunfields imagedisk to control and operate the 8" drive and create, copy, and make disk images to actual disks.
I have a TRS-80 model II, IBM 5120, and MAI basic four mini computer. All have 8" floppy drives. This is one of my many back burner projects... I have so many.
Very cool, let me know how this works out! I already have a DOS machine I use for imaging (5.25" 360k drive, 5.25" 1.2 MB drive + 3.5" 1.44MB drive) - would be very cool to add an 8" to that setup.
