Need assistance copying data from PMC MicroMate 5.25" disks
bit4bit
I have the DeviceSide floppy-to-USB gizmo but it's not working properly with these disks - does anyone have a PMC MicroMate computer that can help?
There is 22DISK that runs on a DOS Computer, and allows you to read/write the PMC Micromate floppy's:
PMC1 PMC Micromate - DSDD 48 tpi 5.25" - 1024 x 5
PMC2 PMC Micromate - DSQD 96 tpi 5.25" - 1024 x 5
cpmtools, or cpmtools built with libdsk also allows accessing Images created by Imagedisk by Dave Dunfield,
or TELEDISK by SYDEX's Chuck Guzis.
cpmtools, libdsk, Flashfloppy/GOTEK definitions follow:
# cpmtools
# PMC1  PMC Micromate - DSDD 48 tpi 5.25" - 1024 x 5
diskdef pmc1
  seclen 1024
  tracks 80
  sectrk 5
  blocksize 2048
  maxdir 128
  skew 1
  boottrk 2
  os 2.2
end
# libdsk
[pmc1]
description = PMC1  PMC Micromate - DSDD 48 tpi 5.25" - 1024 x 5
sides = alt
cylinders = 80
heads = 2
secsize = 1024
sectors = 5
secbase = 1
datarate = DD
# Flashfloppy/GOTEK
[pmc1]
cyls = 80
heads = 2
secs = 5
interleave = 1
bps = 1024
id = 1
#rpm = 360
rpm = 300
rate = 250
mode = mfm
iam = no
# cpmtools
# PMC2  PMC Micromate - DSQD 96 tpi 5.25" - 1024 x 5
diskdef pmc2
  seclen 1024
  tracks 160
  sectrk 5
  blocksize 2048
  maxdir 256
  skew 1
  boottrk 2
  os 2.2
end
# libdsk
[pmc2]
description = PMC2  PMC Micromate - DSQD 96 tpi 5.25" - 1024 x 5
sides = alt
cylinders = 160
heads = 2
secsize = 1024
sectors = 5
secbase = 1
datarate = DD
# Flashfloppy/GOTEK
[pmc2]
cyls = 160
heads = 2
secs = 5
interleave = 1
bps = 1024
id = 1
#rpm = 360
rpm = 300
rate = 500
mode = mfm
iam = no
Here is a directory for CPMMAST.RAW
$ cpmls -f pmc1 -D CPMMAST.RAW
     Name    Bytes   Recs  Attr     update             create
-       .001     0K      0
ASM     .COM     8K     64
CONFIG  .COM     6K     43
CONVERT .COM     6K     37
COPYSYS .COM     2K     14
CPM3    .SYS    20K    148
DATE    .COM     4K     22  S
DEBUG   .COM    10K     78
DEVICE  .COM     8K     58
DU      .COM     8K     64
FORMAT  .COM     4K     23
GET     .COM     8K     51
ITOH5000.Z80     8K     64
LIST    .SUB     2K      1
LISTT   .COM     2K     16
LISTT   .SUB     2K      1
LOAD    .COM     2K     14
LSWEEP  .COM    16K    125
LU300   .COM    20K    154
M       .COM    20K    146
MBASIC  .COM    24K    190
N       .COM     4K     31
PARKHD  .COM     2K     13
PMCEQU  .LIB     6K     47
PROFILE .SUB     2K      1
SAVE    .COM     2K     14
SD      .COM     4K     30
SETDEF  .COM     4K     32
SUBMIT  .COM     6K     42
SWEEP   .COM    12K     92
UNLOAD  .COM     2K      6
ZASMB   .COM    16K    116
   32 Files occupying    240K,     146K Free.
You have several Direct Messages.
Larry
