I have a 386 machine that I pulled from a local business's attic and I've been having some issues with it. I haven't done much troubleshooting, but based on the fact that it worked correctly for only a few times when I first got it, it's likely a dead battery issue that just had barely enough charge when I got it. I have since removed the barrel battery which didn't leak so corrosion isn't a worry.
The RAM appears to be 2 megs by 4 bits, since just one stick won't get recognized and both sticks in will POST bad.
If there is any documentation you can provide about the board also, that would be much appreciated.
There's not much information, above the copyright between the ISA slots it says something like "386SX BOARD".
