Sabertooth
My 5170 Type 1 MB started having issues recently. I threw in the trusty LankMark ROMS and it shows memory refresh failure. Sometimes it will show it right away, other times maybe the 2nd or 3rd round it will fail.
I broke out the oscope and started tracing things out. The 14.318MHz signal is good and is being converted to 2.28 on pin 2 which goes directly to pin 1 of U88. The output on pin 5 of U88 appears to be the issue which of course feeds the timer for the memory refresh.
Sometimes the output is correct at 1.19MHz and then it fails and starts jumping all over the place for 2 to 12MHz and everywhere in between. Of course as soon as that happens is when the memory refresh will fail. After looking at the schematics, I really don't see any reason for this to happen except for a defective U88 which I changed thinking that's what it had to be. That didn't fix the issue.
Can anyone enlighten me as to why the output from U88 to the timer would just go bezerk like this.
