mykrowyre
I found this Explorer 85 at a yard sale... nobody knew what it was. I had some idea when I saw the floppy drives, and a google search came up with 8085 computer.
I couldn't pass it up, but the computer was missing the CPU and several other IC's. There is some very terrible work in there. I believe it came from a a technical school's electronics repair class.
To me, the board looks unfinished. Looks like the ram was never installed?
The blue cover (not pictured) does not have the key lock on the right. It's attached with only 2 screws in the back and tabs in the front.
I'd like to repair (or finish) it.. I did find the manuals and rom images online.
There is an internal power supply, with a fan, which I have not seen mentioned anywhere, but I did see it in the manual I downloaded online.
I also acquired two 8" floppy drives (CDC-1), but no floppy controller board which I assume goes into the S100 slot.
Any additional information would be great.
Considering nearly all the IC's are missing, it will probably be a complete rebuild.
Thanks
Thanks
