LorneinCanada
- Joined
- Jan 7, 2022
- Messages
- 50
I have been hording this old 386 for many years. Thought it was time to have a go at bringing it back to life. End goal ATM is maybe loading some form of DOS and using it for trying BBS. I'm into HAM radio so maybe if I can figure out how. Maybe BBS over HF. There is a further introduction, what I have tried and finally questions at the bottom. I welcome comments and suggestions on what to read up on, try etc.
I have pretty limited skills especially around software. I'm a mid 50's guy. Built a few PCs from P4 to LGA775. My favorite OS is XP. I dabbled a wee bit with Ubuntu. Its cool but mounting software was a bit much for me. On this project I plan (so far) to use FreeDOS.
So plugged it in and booted it up. I was going to get all fancy and test the PSU first, but that didn't happen. Then it was give it a go with the load limiter in series...... for reasons to many to go into here we ended up just winging it and did a "plug it in and see what happens" approach. No magic smoke. It sent me directly to the bios because the coin battery on the board was dead. I see a 1.2 meg drive A and no drive C. 386-BIOS (C) 1991 American Megatrends Inc. There is a VGA video card, Trident chip. 640k of system RAM. The HD is a Seagate ST3144A apparently it will be 124.6 Meg formatted. Found the HD manual online. I believe the mombo model is MB-1333/40PM-CH. There is no math co processor. I have been told I will want a "a 68-pin pga 80387, it needs to match the dx or sx variety of the cpu.
After a few fire ups I noticed something new I had not before. In the BIOS it detected a floppy.... I didn't look close enough. I assumed since the 3.5 was plugged in and bios said that it was seeing a 3.5. No it sees a 5". My main challenge so far revolves around getting the BIOS to show an enabled HD and Floppy.
Looking at the IO card there are a dozen or so jumpers. Someone helped me out with a link to a web page for it. A Biostar FI33290UIO1012.I played with jumper pin settings. Basically trying to enable the floppy and HD while turning other functions off. Nothing I did was successful.
I have asked this question in another forum. "As to swapping IO cards. I have others. But they are from AT cases, might be some more in the Tandy's or Commodore. Is an ISA IO card interchangeable on any of these?" The feedback I recieved was that most ISA I/O cards should swap on the 386. But maybe not "into" certain Tandy's. I think the question of mobo BIOS being an issue came up. And theres a question pertaining to this below.
So far I have:
Cleaned the ISA slots and video and storage controller card... Not sure of proper nomenclature. The ISA card that the floppy and HDD plug into.
I tested the HD supply power voltages.
Swapped another control card in.
Swapped another HD in from a AT? Pc. The orig was a seagate ST3144A. I thought it was spinning yesterday... But today not sure. Seems dead. I swapped in a Caviar 2120. It spins and the LED on the front lights up on power up. Still nothing in bios. I downloaded manuals for both HDD's to make sure I had the IDE cable plugged in correct, master jumper etc.
I tried prompting the BIOS to default settings.
I tried yet another HD. A Caviar 2540. First I put the HD on my newer pc to see if W10 could read it. It couldn't, but it spun happily for some time. {I don't know what it is about these old HD's and the onboard floppy. But anytime I go near them W10 goes full Cartman on me. (lets see how many figure out that plug lol)} I tried running said HD on the 386 and it did nothing. But eventually I smelled trouble. Not sure if it was just the HD going Chernobyl or the PSU or both..... Need to try the PSU ,outdoors, later and see what we see. HD is definitely dead now. Recently going through the old HD manuals I noted some HDs power in pins were wired in an opposite fashion on some HD's. I don't think that was the case here. I cooked it for sure when I tried spinning up the HD from a variable PSU. I tried putting 12v on the 5v pin by accident and that was fatal.
Perhaps adding fuses or relays between the psu and the components of a vintage pc might be a good idea???? Even if just to save them from me?
Questions:
Do I have to load DOS via the floppy on eacj start up or will it be loaded once and then live so to speak on the HD.
If I can't get the PC to recognize the HD and floppy... Will I have to reprogram the BIOS. Can I reprogram and old BIOS chip.
I would like to try mounting these old HD's to another PC to see if they function. I tried via a USB adapter and a PC on W10. Got nothing. W10 made that mounting sound on the Caviar. But nothing showed up on file manager. Or under the "This PC" tab. Can W10 even recognize the Partitions on old HD's?? I think/ assume we are talking FAT16 or something.
I threw in some screen shots of what I'm seeing in the Bios etc. Not well organized or labeled I'm afraid.
So far I have:
Questions:
