chris2fett
- Joined
- Mar 19, 2023
- Messages
- 23
Newbie here! I grew up with C64/Tandon PC-XT clone/286 clone / 486... etc through modern machines today, and recently decided to dip my toes back into the retro PC community with my "dream" machine... a Leading Edge Model D -2011, with 640KB RAM and 2 floppy drives. Just the desktop is included; no keyboard, no MS-DOS disks, no manuals, no monitor. Per the seller, the machine does power on and goes through the full 640K memory check, then fails to find a boot disk.
So, I've got a few semi-urgent questions and would LOVE any recommendations/advice!
1) The Daewoo motherboard is a custom design, and has integrated monochrome and CGA color graphics via two separate 9 pin monitor connectors (see photo). Since I do not have a CRT, I plan to connect this to a standard LCD monitor 15 pin VGA DSUB connection. What type of adaptor and/or cable should I purchase? I am very confused researching this online, as many cables and or/adaptors sound like they are used for serial data transmission rather than video signal(?)
2) I've LOVE to have an XT-IDE CF type device for the 8 bit ISA bus (no hard drive included), but after online research and YouTube video reviews, I am still uncertain if this will even work with my Daewoo motherboard. Specifically:
a> It appears that I need to get MS-DOS or PC-DOS 3.2 or 3.3 to get the thing installed, but that limits my CF size to 32 MB. Higher versions of DOS seem to have more issues with initial installation? But the CF partition can hit 2GB. I would love DOS 5 or 6.2, but I am trying to avoid the memory overhead in a 640K system
b> CF cards are very finnicky and some work/some don't/trial and error approach, is this correct?
c> Do I even need the plug-in card XT-IDE with bios IF my Daewoo motherboard already has an IDE hard drive controller port? Could I not just plug my CF into the small passthrough adaptor, directly into the motherboard?
THIS is what I was first thinking I would need... an 8 bit ISA card with it's own XT-IDE BIOS installed, and built in CF adaptor
....but would something like THIS be enough fo an XT class PC?
