QUICK UPDATE / and a question:
Well, the Model D arrived. I gave a quick glance at the motherboard, nothing obvious/ worrisome standing out. Looked remarkably clean. Battery was not bulging. Hit the power switch, and passed the smoke test. Inserted the 16 bit Trident 9000 based video card into the 8 bit ISA slot and hooked up the 15 pin D-SUB cable to an LCD monitor. Placed a PC-DOS 3.30 boot disk in the drive, reset the machine... and it booted to DOS! Tried some original booter disks, and they worked as well.
Both of the Toshiba A: and B: drives are reading and writing to 360K diskettes just fine. The previous owner(s) must have taken good care of this little gem, either that or it sat in a climate controlled closet for decades
I CAN NOT TELL YOU how relieved I am that everthing is working (so far). My next goal is to get an XT-IDE CF drive installed, but Adrian Black's video made me think that I MIGHT have to upgrade the Phoenix BIOS (I have no way to do that at present). And I can not find any other mentions online of using a CF adapter in a Leading Edge Model D.
QUESTION: Am I likely limited by the motherboard BIOS when it comes to XT-IDE?
QUESTION: My 640K ram check cycles through TWICE before it boots the PC-DOS disk. I don't seem to recall my other 1980's era MS-DOS machines doing this back in the day. is this a normal variant?
