peclark
I've been doing some research to see if I can use a gotek/flashfloppy with my Next Cube. I can't seem to find the pinout documented anywhere. I've been doing a little reverse engineering and I'm assuming the pinout isn't too different than standard, other than power delivery on the ribbon cable, and probably one of the pins being used for 2.88 sense. Here's what I've put together so far, wondering if anyone has the pinout documented?
Pete
Pin | Signal | Description | Pin | Signal | Description | |
1 | ? | Is this used? | 2 | DENSEL | Density Select 1=Low/0=High | |
3 | ? | Is this used? | 4 | RSVD | Is this used? | |
5 | "+5V" | 6 | RSVD | Is this used? | ||
7 | "+5V" | 8 | INDEX# | Index | ||
9 | "+5V" | 10 | MOTEA# | Motor A Enable | ||
11 | "+5V" | 12 | DRVSB | Drive Select B | ||
13 | GND | 14 | DRVSA | Drive Select A | ||
15 | GND | 16 | MOTEB# | Motor B Enable | ||
17 | ? | Is this used? | 18 | DIR# | Direction Select | |
19 | GND | 20 | STEP# | Head Step | ||
21 | GND | 22 | WDATA | Write Data | ||
23 | GND | 24 | WGATE# | Floppy Write Enable | ||
25 | GND | 26 | TRK0# | Track 0 | ||
27 | ? | Is this used? | 28 | WPT# | Write Protect | |
29 | GND | 30 | RDATA | Read Data | ||
31 | GND | 32 | HDSEL#/SIDE | Head Select / Side select | ||
33 | GND | 34 | DSKCHG# | Disk Change |
Pete
