pcdata76
I found a 256/512 kB system board of 5170 with 128k piggybacked memory on a local auction website. I requested from owner to check the board by connecting an ISA video adapter and AT power supply. He did, but said that he couldn't get a video. The board has one missing memory chip on Bank1 (second) but in this case it should throw a parity error if i'm correct. Btw, i have few questions about the board since i didn't own and used a 5170 and i have a limited knowledge about these boards.
1- Does 5170 board post with missing/faulty chips on Bank 1?
2- Can i use 4164 chips instead of 128k piggybacked chips (with reduced system memory of course) if i replace all 128k chips with 64k ones in a bank?
3- Can i diagnose the board using a POST card? Does it throw a code to the post card even if there is a faulty memory chip on Bank 0 or POST card is simply useless on 5170s too as in the case with 5150?
4- Does a 8-bit conventional memory expansion card like AST 6pakplus work on 5170 or i need 16-bit memory expansion card?
