jasa1063
Try disconnecting pin 34 on the floppy cable at the 360k drive. This pin is used for DSKCHG on high density drives but on 360k drives it is usually disconnected or is sometimes used for DISK Ready. This can confuse some floppy controllers, if pin 34 is disconnected, the drive will still function perfectly and you might find the problem goes away.
Thanks, I will give that a try, otherwise I got around the problem by using Norton Utilities SF (Safe Format) utility. This formats the diskettes just fine as it seems to honor the DRIVPARM config in option I setup in the CONFIG.SYS.
