Odd (to me) monitor issue
marc.hull
I have a Commodore 1084 monitor that has a bit of an issues. If I set it to composite video it works fine. If I set it to RGB (analog) then the red is shifted almost one char space to the right. Anyone have any ideas ?
SEgamer
GA, USA
Sounds like the delay for the red signal is off. If you're 100% certain it's the monitor, then I think it can be adjusted by turning some potentiometers on the yoke board (board that connects to the end of the CRT, I think it's called a deflection circuit). Of course, it is very dangerous working inside a monitor so make sure to take precautions or take it to someone who knows how to safely work on monitors.
