1 'On an IBM PC or compatible, use this BASICA program to convert a
2 'Kermit .BOO file to its original form. The result is usually an
3 '.EXE file. The program will prompt you for the file specifications
4 'of the input file and the output file, showing the defaults for
5 'each. The default for the input file is MSKERMIT.BOO. The default
6 'for the output file will be the file specification in the first line
7 'of the input file.
8 '
9 'Because of the way BASICA does its file I/O, an end-of-file
10 'character (control Z = hex 1A) will be added to the end of the
11 'output file. This character will be included in the length of
12 'the output file.
13 '
14 'This program is based on MSPCTRAN.BAS by Bill Catchings, and it
15 'uses the same algorithm. Many changes have been made to speed the
16 'program up. It runs in 45% to 60% of the time that MSPCTRAN.BAS
17 'takes. Using a hard disk, this program will convert the 59,394
18 'byte file named MSJRD5G.BOO in about 12 1/2 minutes. Using a
19 'floppy disk instead, this program will do the same conversion in
20 'about 14 minutes.
21 '
22 'Developmemt and testing were done on an IBM PC XT using PC-DOS
23 '2.1 and IBM BASICA 2.0. In CONFIG.SYS, BUFFERS=8.
24 '
25 ' Alan H. Holland FEAHH at VTVM1 on BITNET
26 ' 5/12/86
100 defint a-z
110 z = asc("0")
120 t = asc("~") - z
200 fid$ = "MSKERMIT.BOO"
210 print "Enter the file specification of the file to be deBOOed."
220 print "<CR> for default ["; fid$;
230 line input "] :", fi$
240 print
250 if len(fi$) = 0 then fi$ = fid$
260 open fi$ for input as #1
300 line input #1, fod$
310 if len(fod$) <= 12 then goto 400
320 print "Error: The format of the .BOO file is incorrect."
330 close #1
340 system
400 print "Enter the file specification of the output file."
410 print "<CR> for default ["; fod$;
420 line input "] :", fo$
430 print
440 if len (fo$) = 0 then fo$ = fod$
450 t1$ = time$
470 print "Processing started at: "; t1$
480 open fo$ for output as #2
500 if eof(1) goto 800
510 input #1, x$
600 if len(x$) < 2 goto 500
610 a = asc(x$) - z
620 b = asc( mid$(x$,2,1) ) - z
630 if a = t goto 700
640 if len(x$) < 4 goto 500
650 c = asc( mid$(x$,3,1) ) - z
660 d = asc( mid$(x$,4,1) ) - z
670 print#2,chr$(a*4+b\16 and 255);chr$(b*16+c\4 and 255);chr$(c*64+d and 255);
680 x$ = mid$(x$,5)
690 goto 600
700 print #2, string$(b,0);
710 x$ = mid$(x$,3)
720 goto 600
800 close #1, #2
810 t2$ = time$
820 print "Processing finished at: "; t2$
850 system
