olePigeon
There were three kinds of upgrades. The very first was the HyperDrive from GCC, which could be done at home if you were very careful and good at following directions. This one clipped onto the CPU. Later versions used an easy Killy Clip so no special tools were needed. This one was especially cool, though, because this was well before the Plus. So GCC had to do all the SCSI implementation in-house working with the original 128k and 512k ROMs.
The second kind required soldering and dealer installation:
The third and easiest were ones like the Dove MacSnap. The RAM upgrade clipped onto the CPU either by using a killy clip or by just pulling the CPU out, but you could buy a separate SCSI board that clipped into the ROM socket and replaced the ROMs with Plus ROMs. Lots of companies sold variations of the SCSI upgrade since it was relatively simple to build and worked independent of any other upgrades. You could even stick it in a 128k, but when you add the SCSI manager, it left no RAM to actually run any apps.
