ChrisCwmbran
Hi all,
Hoping one of you Osborne 1 gurus can confirm that the following is correct:
I have an Osborne 1 (B version) which has a version 1.43 BIOS. The machine appears to be fitted with two TM100-1 single sided 48tpi floppy disk drives. If I fit the machine with a double density option board the machine will then be able to read double density disks? I don't need to do anything else?
The reason I ask is as it stands my tweener will not write single density disks. Given I have two spare double density disk boards for the Osborne 1 it would seem this is the easiest and best way to solve the problem.
Thanks in advance,
Chris.
Thanks in advance,
Chris.
