I have an Osborne OCC 1 I'm trying to repair, and I observe the following behavior:
1. Machine beeps on power-on and I see some introductory text on screen, including "ROM Rev 1.5/DD" and "Insert Disk into Drive A and press RETURN ...."
2. Nothing happens when I press return with disks in both drives.
I verified that the keyboard cable is plugged into the bottom of the keyboard, and the cable is attached to the machine with the output plug coming left. It's the style of plug (later style?) where it's a spiral cable in a 90 degree connector that has locking brackets.
If I press the physical soft reset button the text on the screen flickers repeatedly or disappears entirely
I opened the machine and swapped the two drives with no change in behavior. The FDD cables also seem to be connected properly to the system board (to a little riser board that connects to the main board).
(Surely unrelated, but I haven't yet replaced the two filter caps on the PSU)
Any ideas on where to start?
